z32 brakes
  • z32 brakes
    what size are the bolts holding on a z32 front caliper. 1990 NA. and what size wrench for the lines?
    also does anyone know what fastener holds the plenum on a z32 . allen key socket like ours????
    i am removing stuff in 6 inches of mud at a wrecking yard so i don't want to f*** around.
    thanks,
    andrew
    Andrew
    all the brake lines are a 10mm... be sure to bring a flare wrench.. but if its coming off a junkyard car just bring some dykes and cut the hard lines.. then you can worry about rusted fittings after letting them soak for a while after you already have the lines in your possession. the bolts that hold the calipers to the strut housing are either a 17 or 19MM... not sure about the z32 plenum.. have fun in the mud
      thanks
      thanks alot. yeah i am just gonna cut the line farther back.
      Andrew
