He sent me the pictures to post so here they are. I'm going to make one using the same part and a similar method! Very cool.
Russ' home made poly diff mount
hmm not a lot of lateral support.... I've seen a cutaway of it, it's designed for twisting forces, kinda the idea gary was after but couldn't make work
I've updated my design and hope to have it in metal by mid next week, I changed it so that the "bushings" will be under compression but still easy to put in, and will be lower profile than previously
also I whipped up some stock trans mount "stiffener" plates you hammer in to the C shaped piece to help prevent twist, but you still retain the up and down softness of the rubber, I'll be tossing these out for $15 I think
I need some frickling batteries
autoworkZ wrote: what application is the poly mount for? some sort of mustang?
I just ordered one after reading through the dimensions on a few of them, it's not the same as russ' but the tabs are spaced exactly the same as the studs on the body, so it should be even easier to install if I can get everything to line up correctly.
Update
Last weekend I managed to put my Z into a curb at an AutoX event.
The rear control arm is toast. The Panasport is history. The Crossmember bracket that holds the toe adjustment of the control arm is only slightly bent.
84 parts car is on the trailer in the drive soaking the crossmember parts.
The hit compressed the halfshaft and knocked the Differential over about a half inch. The reason for the post is that the differential mount came through it all without a scratch.
Have an event in two weeks it should be ready.
Just got back from Beaver Run where we put on an autoX in conjunction with a race day NASA was putting on. Weather was great, people were great, I think most everyone got in at least 12 runs plus 5 fun runs, and acouple of laps around the race track. Not bad for $25.00. I had to do my runs in a Kart, Super seven and a turbo charged Miata....and how much HP do you have at 0 boost
That's a total bummer man...sad to see someone lose a panasportAttached Files
2006 Scion tC (Wife Whip)
take pics I wanna see the carnage
Jason84NA2T wrote: That's a shame! Why did they build a course so that was even possible to do?
It was a charity event. The group we were putting on the event for had the site so we did a course for them and ran the event. I will never do another event without at least 20 ft. margin.
I wanna know how you knocked the diff anywhere.... it's quite solidly bolted to the subframe.. are you saying the subframe or diff housing bent or the bolts sheared?
take pics I wanna see the....and how much HP do you have at 0 boost
Update
Got the car back together and the alinment was perfect. -3.5 camber and .06 toe in the rear, -2.0 camber and -.06 toe in front. Finished first in class in Saturday. Only problem was the Differential mount let go for the last three runs. Diff dropped and the halfshaft almost wore a hole in the exhaust.
Turns out that it was my fault not the mounts. The mount wasn't tight enough and slipped out of the bolt. I took the assembly apart and the poly mount is still intact. I had to straighten the flanges and I am rethinking how to mount it to the frame. I think I will weld it to a plate and then bolt that to the frame.
The Poly mount was a GM transmission mount #3.1108 from Energy suspensions. The Ford mount #4.1128 is alittle larger and might also work....and how much HP do you have at 0 boost
post pics dammit, I want to see blood and destruction!
in other news, my camber adjusting diff mount proto units #2 and #3 are in progress, of course I won't be able to accurately tell anyone what camber +/- you can get since it will depend on the springs and their condition.... but with toe-bolts on both control arm points, lowering springs and the adjustable diff mount, you should be able to get almost any geometry
