Benedict wrote: Zmech you chose S14 knuckles because 5-lug is typically cheaper correct?
Zmech/Buter...
Is there enough difference in S13/14 knuckles and coilovers to doubt that this conversion could be done using S13 parts?
reason being, in my case, I already have dibs on complete S13 front and rear suspension for free.
I know the balljoint is different (S13 smaller than S14, but is S13 smaller or larger than Z31?) If there's no conclusive answer I guess I'll just have to start bolting stuff up and see.
Zmech/Buter...
No, you cannot use S13 spindles because the front axel centerline is different; the spindle is offset from the center of the strut changing wheelbase, along with caster and SAI dramatically. S13 5 lug is also an expensive conversion.
