i finally got some rear control arm bushings. this maybe a newbie question.
how long did it take you to replace them?
i've got my MAP gas ready to go. i'm going to cook them then remove the metal sleeve. and then replace the rubber with poly.
do i need to remove the whole arm or can i do this under the car without removing everything? i was hoping i could just remove the mounting bolts, drop down the arm and go to town.
thanks
thanks
