I’m kind of in a pinch this week by A4 being down and now my Z giving me trouble. I did finally get the front spindle bolt off (26mm thanks G-E) and the front outer bearing had broke like I thought, but in the process fusing itself to the spindle. Well after I got most of it off it was clear that the whole thing needed to be replaced because of the damage done to the spindle.
My Z is a 87 na. the only junk yard around has one from an 88 turbo. From what I have found I need to get on from another 87-89 na because the turbos had bigger diameter struts.
Please tell me I’m wrong and I can use the one from a turbo. If not does anyone had one for sale that I can get fast? Passenger side.
This is the pieces that I’m talking about just in case I’m using the wrong terminology.
Yes I pulled the image from Jasons site.
