z
brake problem, what gives? UPDATED 2
I would not recommend using a clamp on the rubber lines. If you want to block off a line, plug it. You can even plug it at the master. If you are not losing fluid and the pedal is soft, its the master.Chuck Stong
http://www.300-plus.com
Firehawk wrote: I would not recommend using a clamp on the rubber lines. If you want to block off a line, plug it. You can even plug it at the master. If you are not losing fluid and the pedal is soft, its the master.
I have a hard time believing VB sent me two consecutive DOA masters. Especially since it passes the screwdriver test (granted i know that screwdriver doesn't apply near as much force as the booster would).My beloved Z:1987 2+2 NA2T w/30a swap.
Chris86NA2T wrote:
a bad brake booster does not necessarily mean that you loose power assistMy beloved Z:1987 2+2 NA2T w/30a swap.
Don't go by your screw driver test as it will not provide even fraction of the force the brakes need. The brake booster uses vacuum to help apply force when you apply pressure. If the booster was bad, just makes you press the pedal harder to apply the same brake pressure.
I have had three consecutive bad masters that were all supposed to be remaned. I wonder if they just cleaned up and repackaged old cores.
And khyronzx, lose the attitude. This is not z31.com.Chuck Stong
sorry, see edited post, had about the same problem a few months back, just went to the parts store and got a new m/c, not remanned, problem solved. here is kinda a easy test have someone pump the brakes, while you listen to the master cylinder, if it is as bad as it sounds, you'll problably be able to hear the brake fluid rushing past the seals.
"Beer is proof that god wants us to be happy" - Benjamin Franklin
You could have air sneaking in through the threads of the bleeders if they're old and rusty, pull them all the way out put some teflon tape on them and try bleeding them again
khyronzx wrote: You could have air sneaking in through the threads of the bleeders if they're old and rusty, pull them all the way out put some teflon tape on them and try bleeding them again
I called VB, they do no sell manufactured masters, this is the 2nd NEW one I've had on there. I told them I'd fuck with it some more before having them send me another one.My beloved Z:1987 2+2 NA2T w/30a swap.
FWIW I had similar issues. Tried a lot of things but eventually changed the M/C. I had a spare that looked new and it did the trick. The old M/C was a Tokico but it did not say NISSAN on the side. The new one is a Nabco. bench bleed - for a long time to get every little bubble out, installed and flushed the system with new fluid.
