DrewZee87T wrote: It is a fixed caliper. The 87+ setup with slip on rotors that I am running does not perfectly center the rotor in the caliper - but it is a small difference. There is a small space that is off which is why some people advocate putting spacers in to push the caliper out a bit and thus center the rotor more exactly. The caliper is fixed, and the rotor is fixed, so the slack is taken up by the pistons. That means that you need to just keep an eye on your brakes (which you should do anyway as normal maintenance) to make sure you don't wear the outside pad to the point where the piston wants to overextend the caliper.
I have never heard of this happening, and I figure they put enough piston in the caliper to allow for a certain amount of overextension. So far, I have had no problems.
As to how this would impact your car if you were running 15" stock wheels, if they fit without the spacers, you should be good to go. If you put spacers in, they may not fit anymore.
The bigger question is what do you do when you have a flat front tire? That one I have not figured out yet. I am pretty sure the donut (and quite positive that the NOS bottle that sits where the donut used to live) won't fit. That's the biggest worry I have with TT brakes. What happens when I have bad tire luck. Right now the answer is a can of fixaflat and pray. Otherwise its call a truck and ask them to bring a wheel or tow you home.
Think that through on your next cross country journey, it might be a good idea to have a spare.....
