Ok, so I have found that it looks as though the WRX 06 has the aluminum sumitomo calipers (same as the TT calipers)
Also the 79-83 toyota 4wd trucks use these as well, as can be seen here installed on a 280 zx http://images.google.com/imgres?imgurl= ... 47,GGLD:en
06+ WRX are the same, but I don't believe the toyotas are.
Yes sorry, you are correct. What I ment to say is that the trucks use 4 pot calipers. They dont even look the same though. However if they bolt toa 280 then they will bolt to 300's right?
I'm pretty sure the bolt spacing and offset is different, so no they won't.
