front end toe adjustments are made with the tie rod.
improper wear out of front tires
Get the alignment (buy a lifetime policy if you are going to keep the car) and the numbers will tell you what is wrong. Bad toe will cause more wear than anything, but if something else is way out of spec, you will need to fix it.Chuck Stong
http://www.300-plus.com
I just fixed the front alignment on an audi, due to the fact that the body curves and the rear wheels toe-in it's hard to get it perfect
as it is I did it manually and got it really close but will still wander a bit on off-camber roads.... part of the problem is I have no perfectly flat surfaces/roads to adjust it on and its a matter of trying to average what you feel driving and what you see
Firehawk wrote: Get the alignment (buy a lifetime policy if you are going to keep the car) and the numbers will tell you what is wrong.
Shouldve taken some pictures of my rear tyres before I got them replaced, has the bad camber & completely wore away the insides of them. Wish you could just flip em around & that way I would have perfectly good rubber on them. :P
1985' 2+2 Z31 Non Turbo...
1986' 2+2 Z31 Turbo...
Adman85zx wrote: Shouldve taken some pictures of my rear tyres before I got them replaced, has the bad camber & completely wore away the insides of them. Wish you could just flip em around & that way I would have perfectly good rubber on them. :P
