Jack points...
  • Jack points...
    Does anyone else seem to have week unibody rail things?
    Mine fold over no matter what i do, and i have to hammer them back, it takes for ever.
    Is there some kind of rail i could slip over and tack weld on?
    Or is there a better alternative jacking point?
    Thanks ahead of time.
    I use the center of the crossmembers.
    That is with a floor jack though.
    Perhaps you could carve a channel into a block of wood to
    fit the frame rail?
    imagination is a virtue
      Could try opening your FSM, there's a picture of all the "advised" jack points in there.
      Personally I only lift on either of the crossmembers, or diff.
        I concur.... I made the slitted block of wood adapters to jack the unibody pinch seam, but unless I only need 1 wheel off the ground - which is rare - I use the crossmembers
          The piece of wood like these guys mention for the frame rails works great.
            :shock: I prefer to box the craptacticular oem rails with 1/8" plate....making them so strong that I can lift anywhere I want on the rails without issues. Strong?..... I can place a floor jack between the tires on the rail on one side of the car and lift the entire one side of the car with no problems.
            *This does effectively firm up the chassis too!
            I am here to help...
              dan, can you make me some dinner plates? :P
              somehow my dishes are never that clean
                yeah, i am just tired of the rails being lame.
                Thanks guys, i will try dans idea if i can get everything straight.
                  WaZZ300 wrote: yeah, i am just tired of the rails being lame.
                  I'm lucky to own 2 Z31's with un-crushed rails (for the most part). 90% of them I see have been comppletely crushed flat in at least one spot. I have a nasty habit of looking under cars quite frequently...
                    Ditto
                    2008 BMW E92 335i 6MT
                      My employer sells a nice hydraulic jack that works in the stock jacking point so you don't have to dick around with wood.
                      Just in case you're wondering, I'm Pylon_Boy
                      I'm moving out of the country. Buy my tools, cars, car parts, ect.
                      http://search.ebay.com/_W0QQsassZpylon_boyQQhtZ-1
                        Yeah, I've never seen one without crushed rails. Planning on wedling in plates over the whole frame.
                        Drive
                        1975 Datsun 280Z
                        1988 300ZX (NAtoT soon)
                        2006 Kawasaki ZX6R
                          that underbody is soooo clean i wish my interior was 1/2 as clean as the underbody
                          Stocker 87 na z31 and a slightly modded 90 240sx
                          • #14
                            My rails were unfortuantely raped by the previous owner
                            1988 300zx Turbo, Shiro Edition #21
                            • #15
                              FreeLanceBum wrote: Yeah, I've never seen one without crushed rails. Planning on wedling in plates over the whole frame.
                              Like this? As seen at: http://home.comcast.net/~gwmolitor/frame_repair.html
