Using more pistons is not the end all for more braking performance. The right pad compound is the most critical aspect, then rotor size/thickness (mass). If you are running 13" rotors it would be beneficial to use 2-piece rotors for the weight savings and better options for directional vaned rotors which will greatly enhance brake cooling and durability.
I am currently refurbishing some vintage AP Racing/Stillen 4-piston 13" 2-piece Z32 front BBK for use on my 86T.
