i guess the wheel gap don`t bother him...
  • i guess the wheel gap don`t bother him...
    http://gtfabrications.com/gtf_pg/displa ... m=28&pos=9
    http://gtfabrications.com/gtf_pg/index.php
    good thing....
    Hmmmmm. VERY interesting. I measured up S13 spindles and found it would place the wheel wrong when used with Z31 control arms, and then butter said that an S14 spindle placed the wheel back in the wheel well about an inch? I never compared the control arms side by side:
    Now I am seriously wondering if the entire S14 front suspension he appears to have under there:
    Is just a swap-on deal (save for the tension rods). Again, VERY interesting.
      Result of using S14 front suspension:WRONG.
      Massive battleship on the front too. Caster is MAD jacked up.
      IIRC...
      S13 Arms= @15mm longer
      S14 Arms= @25mm longer
      The big problem would be finding tie rods long enough to work with them. I don't like really long rods, so I wanted to maybe do a rack swap. Didn't seem to be worth the money/effort, so I went adjustable arms. Still would like slightly longer tie rods. My arms are adjusted out about 10mm more than 85t and the threads on the tie rods are near the "scary zone".
      sigpic
        BUTTER are you sure you weren't going for the bitchin camaro look ? how did finally fix that setup?
        boost. does a body good!
          jjewell wrote: BUTTER are you sure you weren't going for the bitchin camaro look ? how did finally fix that setup?
          He modified the shock towers in back and used Z31 spindles up front.
            That front spoiler lip wont last 5 minutes with that setup...
            http://youtube.com/c/zcartube
