has anyone used a brake mc for clutch?
  • has anyone used a brake mc for clutch?
    I'm just pondering the idea, you would get very quick actuation from the slave with barely any clutch pedal movement
    you could lave an inch or more of play and still be in/out in less than an inch after that point
    I think youd be better off using a mismatched master/slave. You could probably find a slightly smaller diameter slave and a slightly larger diameter master and accomplish something similar to the brake master idea.
      Stinky wrote: I think youd be better off using a mismatched master/slave. You could probably find a slightly smaller diameter slave and a slightly larger diameter master and accomplish something similar to the brake master idea.
      Yeah, (I think it's 240sx) guys do that when they put in a HD pressure plate.
      I'm not sure why you would want less movement or damping from the clutch pedal. If anything, I would desire more so you can still modulate a higher clamp load unit fairly well at the engagement point.
      I'm pretty sure a brake MC would not work in place of our clutch MC.
