The Poly transmission mounts are about to be released. There has been a flawless beta test and the final order of 50 units has been placed. Final pricing is $99 shipped via UPS, with $10 off if you bought/buy engine isolators as well. This makes the combined kit $199 shipped. You can get one ASAP by contacting me before I release them to HybridZ, Z31.com and Zcar.com members.
Additional new products awaiting testing and will most likely be sold by late summer 06:
1. Replacement poly bushings for harmonic damper bar:
The big dumbell shaped thing that is part of your transmission crossmember has large, soft bushings. These replacement poly units are soft enough that the bar retains some function, but will still greatly enhance performance.
2. Aluminum transmission crossmember:
This unit will entirely replace the transmission crossmember in favor of a lightweight aluminum part. This part will work in conjunction with the poly transmission mount isolator and reduce complexity, save weight, and allow installation of late/early transmissions without the need drill and tap new holes on the cars unibody.
No prices will be announced yet, but most likely the more people show interest and the more are produced, the lower the cost will be.
