I just changed gear oils in my T5 (FS5R90A) and the rear differential (Quaife). In the transmission I changed from ATF to Liqui Moly GL-3+ and in the rear to Liqui Moly GL-5. Right in front of me is the 1985 OEM Nissan 300ZX FSM and on page GI-13 it specifically states that in the T5 Turbo model one can use either GL-4 or Type DEXRON, which is an ATF. For some reason, non-turbo models cannot use ATF. Liqui Moly GL-3+ is usable for GL-3 and GL-4 applications and is made to work with brass syncros. GL-5 is too slippery for the T5 brass syncros --- and believe me, it is the slipperiest oil I have ever felt.
synthetic or conventional
Originally posted by NewJerseyZ View PostFor some reason, non-turbo models cannot use ATF.
Originally posted by frostvectron View Post
No, actually he is right. You fill until fluid starts coming out of the fill hole. How the heck are you supposed to fill the case to the top of the fill hole when it is pouring out of said hole?
@OP. Mobil 1 Synthetic Gear Lubricant LS 75w-90 is an API GL-5 product which is intended for extreme pressure protection in differentials and not transmissions. The sulfur/phosphorous content is too high and will corrode the brass synchros in our transmissions.
Ummm. I remember reading a pretty old post about GL4 vs GL5 oils. There was a recommendation for Motul Gear 300, which I am currently using... but now I am googling it and a few results pop up saying the Motul Gear 300 is GL4/GL5 (i.e. not good for GL4-only applications)... did something change?
E4N71B Automatic transmission: ATF DEXRON
FS5W71C 5-speed transmission: Nissan recommends API GL-4 (SAE 75w-90)
Non-World Class T5: API GL-4 (SAE 80w-90) or Type DEXRON. The FSM is outdated and things have changed since the Z31 made its debut. I could go into details about DEXRON, but to avoid confusion look for DEXRON III which is still sold, or ATF labeled "Dex/Merc." Buy a trusted brand such as Valvoline.
80w-90 is what I use in my T5 transmission, and it has many additives that provide cushioning for the gears and syncros. It works perfectly fine in the spring and summer months. However, it's thicker in cold weather which can result in slower shifts. That's why some folks recommend using ATF. ATF 10w is lighter so you'll get quicker shifts in cold weather. Synthetic gear oil has the same viscosity as conventional gear oil, but a higher flow rate. Therefore, it will also provide quicker shifts in cold weather. However, I don't drive in the winter months and the car is over 30 years old. In this case, conventional 80w-90 is fine for me. Saves on the wallet. If you drive your Z in cold weather, by all means use ATF or synthetic.
As I stated, DEXRON III or ATF Dex/Merc is recommended for the NWC T-5. but not API GL-5. API GL-5 contains twice as much sulfur/phosphorous as API GL-4 which is corrosive to the brass synchronizers. That will cause your synchronizers to wear out extremely fast. API-GL 5 is needed for extreme pressure protection in the differential where the final torque is applied. The higher sulfur/phosphorous content helps it bond to the brass. API GL-4 is used in the transmission where the extreme pressure protection isn't needed. Only 30% of the torque is applied in the transmission.
World Class T-5: ****ATF DEXRON III****. The World Class T5 came with a sticker on it that said, "ATF Only." They don't use heavy gear oil or Redline MTL.
Originally posted by frostvectron View PostUmmm. I remember reading a pretty old post about GL4 vs GL5 oils. There was a recommendation for Motul Gear 300, which I am currently using... but now I am googling it and a few results pop up saying the Motul Gear 300 is GL4/GL5 (i.e. not good for GL4-only applications)... did something change?
Usual Z31 suspect: Garage Queen (aka broken)
