Thanks for extracting those from Gregs album, i edited his post with the links you uploaded and archived page 1 in PDF format on my google drive
DIY: How to rebuild the 88-89 300ZX headlight switch with new contacts
This is a sticky topic.
Originally posted by kaur View PostAnd this is a Sentra headlight switch. The connector is at a slightly different position, but I got this brand new OEM switch for $27 and I hope it will still fit.
A few other Nissan part numbers that should work and should be cheaper than the S13 switch:
25540-75P08 (tested, works perfectly with the contacts part swapped over)
25540-65E00
25540-78J00
When doing this fix, it's also good to add some lube. The lube should be something that's made for plastic parts.
- 1 like
