Coolant gauge on the cluster constantly reads middle. ECU signal is correct via NisTune, and fans are kicking in at proper temp. This was not an issue previously. Last work on the EFI loom was wiring in plugs for the injectors, nothing was modified with temp sensor, wiring, or connector. Any one have some common causes I should address first?
Also, oil pressure sensor is not sending signal. I have yet to meter the sensor. My first thought is that I have the incorrect sensor, I'm running needle gauges. The FSM only has one method for metering sensor resistance w/engine ON/OFF. This makes me question why there would be two part numbers for analog or digital gauges. The sensor was cleaned and bored out, no signal continues. Again, any common causes or easy check to perform before replacing the sensor?
Thanks!
Thanks!
