Trying to access the turn signal flasher relay to test it, I can't seem to find it anywhere. The FSM suggests that it's behind the gauge cluster, do I need to remove the cluster?
Can't find turn signal flasher
I found it, right by the steering shaft like Dunkine pictured, My car is an 88T, maybe the Zenki has it behind the dash.
I smacked it on the table a few times and all is well again. I've been manually blinking my signals since BZF 2014 (flasher failed after a big storm). Thanks for the help.
