Ok so the title makes it pretty easy to understand what my problem is. Questions is why? I took the gauges out and on the connector that I assume is for the tach had 3 wires. Black is ground green is constant 12v and yellow I assume is the signal wire but it has no reading at all. So either a can someone explain why or b can someone give me a way to to splice into where the signa comes from and run a wire to that yellow one so it has the signal?[*]
tach not working
So what I assumed about the connector for the tach is right. Black=ground, green=power and yellow=signal. After looking at the diagram in the haynes a wire labeled L comes from the coil and goes into a resistor then Y (yellow) wire goes from the resistor to the tach. I cant remember what color L is for the diagram, but more importantly where is the resistor that that wire runs to?Hot Red 1987 Turbo VG30ET, VG33 heads, Isky 280/280 cams, SBE, gt3582r, Pucker factory intake/exhaust manifolds, ms3 pro goldbox, making 610whp at 29psi on e85
Here is what the FSM shows.
Feedback thread
http://www.z31performance.net/showth...p?40386-sir420
The Herd
85 z31 GLL N/A2T (7psi daily){Totaled 1-24-2012}
85 z31 GL N/A2T slightly modified
85 z31 GLL Turbo Kaminari converted to N/A
85 z31 GLL Turbo (parted out)(scrapped)
90 s13 se n/a (stock)Wife blew up the engine
88 xj40/xj6 (stock) Yard Art
88 Mighty Max
99 WJ 4.7 Limited
one_fast_300zx wrote: So what I assumed about the connector for the tach is right. Black=ground, green=power and yellow=signal. After looking at the diagram in the haynes a wire labeled L comes from the coil and goes into a resistor then Y (yellow) wire goes from the resistor to the tach. I cant remember what color L is for the diagram, but more importantly where is the resistor that that wire runs to?
sir420: thats the same diagram thats in the haynes lol
mikep, thanks for the location, now you know im gona need to take the one from the 88 before you leave with it tomorrow right.Hot Red 1987 Turbo VG30ET, VG33 heads, Isky 280/280 cams, SBE, gt3582r, Pucker factory intake/exhaust manifolds, ms3 pro goldbox, making 610whp at 29psi on e85
So replaced the resistor with the one from the 88, still no tach. Check for signal there, and I have signal. Just isnt going throught the resistor. So does anyone want to mail me one that they know is good and working lol?Hot Red 1987 Turbo VG30ET, VG33 heads, Isky 280/280 cams, SBE, gt3582r, Pucker factory intake/exhaust manifolds, ms3 pro goldbox, making 610whp at 29psi on e85
