Hey guys, my 86' Z31 GLL Turbo Coupe is doing some some weird things lately. Some times at Idle, my Engine RPM's bounce between 700 to 1000rpms and if I tap the throttle it will idle back to normal. Also every now and than on hard acceleration in 1st and 2nd gear my engine feels like it is stalling out,so if I let off the throttle and get back on it, then it runs okay....(if this makes any sense)....Question,will my ECU show any error codes for this and do you happen to know where I can get a list of error codes...Thanx!
ECU ERROR CODES
