HELP!!!!!!HOT COOLANT STARTED LEAKING ON MY FEET!!!
  • HELP!!!!!!HOT COOLANT STARTED LEAKING ON MY FEET!!!
    ....When I was using my heater this 38 degree morning, Hot Coolant started pouring all over my feet from underneath the Dash, WTF happened! Does any one know what component is over the drivers feet area thats related to the heating system...HELP!!!!
    CRAP! AND LET ME GUESS, THERE IS NO SIMPLE FIX FOR THAT BUT RIPPING MY DASH OUT......
      Help!!!!!!hot coolant started leaking on my feet!!!
        F-IT!!!!,I'LL WEAR MY THERMALS AND DRIVING GLOVES INSTEAD!!!!!
          fuelrags wrote: F-IT!!!!,I'LL WEAR MY THERMALS AND DRIVING GLOVES INSTEAD!!!!!
          that isnt going to solve the problem.. you now have an open hole in your cooling system and you will dump all of your coolant real quick. you need to bypass the heater core if you want to drive around with no heat. by the way, i had a heater core hose EXPLODE on me.. getting the thing out wasnt that bad, but with all the cleaning and drying of shit under the dash the job took me 21 hours total
            YEP, I by-passed the heater hose, I live in L.A., it's only cold for maybe another 2 months if that....I'm cleaning out underneath the dash...what a mess...Japan made a bitchin muscle car but stuff like this?!they should have made the heater core more accessable.
              fuelrags wrote: YEP, I by-passed the heater hose, I live in L.A., it's only cold for maybe another 2 months if that....I'm cleaning out underneath the dash...what a mess...Japan made a bitchin muscle car but stuff like this?!they should have made the heater core more accessable.
              seriously... i dont think there is an item on the car that is less accessible
                  HAHAHAHA you said 38 degree MORNING is cold. I leave my house every morning at 630 am and it is roughly 15 degrees out NOT including wind chill. WTF do you need thermals and gloves for!? 38 is a beautiful morning prolly highs of what mid 50's to 60 degrees?
                    Ah..38 degrees would be like heaven compared to what's going on now.
                    I was working outside yesterday morning, a nice fresh 14 degrees...
                      La, i live there. I don't HAVE a heater anymore :lol: , But i understand your pain.
                      Wanna buy a heater core??
                        Just buy a new nissan heater core. The removal of everything is not hard, just time consuming. The dash is easy to pull once you know there are bolts under the defrost vents. It is also a good time to replace all the vacuum hoses for the a/c. Get all the parts and you should be able to do it over a weekend.
                          I have a good spare heatercore, no leaks or corrosion, $40 shipped?
                            Thanks guys, but I'll pass on all that labor just for a Heater Core. I'm really bummed, everything has worked Bitchin' on my car for the past 20 years,now this......
                              Didn't someone once post a writeup on how to replace the heater core by going through the glove box? Can't remember.
