help!!!!!!i have no heat
  • help!!!!!!i have no heat
    i just bought a 86 300zx turbo and after plugging in the climate control i realized that i had no heat at all. the heater core is not leaking. on all the setting besides 1 the a/c is on is that normal. the climate control is digital by the way.
    any answers would be appreciated
    layering is in this year again, wear 3 coats :lol:
    just check your relays and fuses, if further from that check the blower motor, and wiring
      Sounds like a water cock problem. UGH
        k man, look for a vaccum leak, everytime my heat cuts out its due to a leak or broken hose!
          would that cause it to only blow out cold air
            I thought if you had no vaccum to the heater valve it was always open.
              Yep, default for water cock is the open or heat position, but if it's stuck shut, then no coolant will get to the heater core = cold air.
