Re: "Taurus Fan"
1- given the amp draws you posted...you will be pushing your stock 20yo alternator to its limits. :shock: The battery will help absorb the start-up loads but 35 and 40 amp running draws sound a bit high to me. Especially on a stock electrical system. It will probably work for a while but after some use you will probably blow the diodes in the alternator and have to buy something like a 90 amp Maxi unit. I have a 100amp alternator and I wouldn't want to be running a continuous load like that.
2- No its isn't a waist of time. Most of the dual fan Maxima setups and dual aftermarket installs use the dual speed. It is a good idea in my opinion.
3- Inlet.
Overall, I would say verify the running draw on that fan unit. If it is 30+amps continuous then I would suggest the Maxima fans or aftermarket dual fans of your choice that will draw a more reasonable amount. (From what I have read/experienced most aftermarket units will have a start-up draw of about 30-35 amps and run well below that.)
Whatever you do make sure to wire it properly with an adequate relay and in-line fuse so you don't f- up any stock electrical systems. Relays and fuses are your friends... :wink:
Mike_GruiZinga wrote:
1) Will a good condition stock 70 amp alternator support this fan? Why or Why not?
2) Is it a waste of time and money to wire the fan for both speeds? People using this fan in their V8 powered Z's usually on wire for one speed: High.
3) If using fan control which utilizes a radiator temp. probe, where should the probe be placed? Inlet or Outlet?
3- Inlet.
