Runnign lights issue
  • Runnign lights issue
    At least it is your radio stuff. I still haven't figured my running lights issue. Glad you found the issue.
    86t: Only way to learn is to ruin shit. happens to us all
    MrwassmanNA2T wrote: At least it is your radio stuff. I still haven't figured my running lights issue. Glad you found the issue.
    Whats wrong with your lights? I bet I can fix it.
    Chuck Stong
    http://www.300-plus.com
      I bet you can Z master. I finally got a Circuit breaker.
      The plan was to unplug everything the fuse runs off of, pop in the CB. Hopefully there are no short2ground wires. Then plug everything in until i hear the CB pop open.
      Any suggestions? It is the running lights fuse btw.
        MrwassmanNA2T wrote: I bet you can Z master. I finally got a Circuit breaker.
        First thing I would suspect is the light switch. I have seen this several times. Either swap in a known good one or take yours apart and check the contacts that move with the switch.
        Chuck Stong
          I'll try. The headlights still work if that means anything.
          Would that make the fuse blow?
            MrwassmanNA2T wrote: I'll try. The headlights still work if that means anything.
            Yes it can.
            Chuck Stong
              Repair Section?
              "produce first.talk second."
                If someone wants to move this thread, go for it. I see no reason tho
                Recycling :wink:
