If someone wants to move this thread, go for it. I see no reason tho
Recycling :wink:
Runnign lights issue
MrwassmanNA2T wrote: I'll try. The headlights still work if that means anything.
Would that make the fuse blow?
MrwassmanNA2T wrote: I bet you can Z master. I finally got a Circuit breaker.
The plan was to unplug everything the fuse runs off of, pop in the CB. Hopefully there are no short2ground wires. Then plug everything in until i hear the CB pop open.
Any suggestions? It is the running lights fuse btw.
MrwassmanNA2T wrote: At least it is your radio stuff. I still haven't figured my running lights issue. Glad you found the issue.
86t: Only way to learn is to ruin shit. happens to us all
86t: Only way to learn is to ruin shit. happens to us allTags: None
