I haven't seen it mentioned so far and I think it's worth bringing up.
The 88-89 style switches, the ones with different connectors, also have
differently designed fingers. Instead of being straight, they are kinked just at the
spot where the toggle block touches them. This makes it exceedingly difficult to repair this type of switch,
because once you bend it out of whack, it's very hard to get it back into the right shape. I actually gave up
on mine and wired the connector from an earlier model car in so I could use the previous style switch.
I broke into it 3 times and it just kept screwing back up after a day or less. Now that it has the switch
I repaired in the 85 and ran in the truck, it works flawlessly, as it did in the previous vehicles it graced.
Now I'm not saying "rewire your car to use the older style switches". I just want people with 88-89's to be aware
that they are in for a little more than the write ups prepare them for. If you can carefully clean the contacts without
bending the fingers at all, you should be okay. However, the option is there. I didn't use the FSM
but a simple comparison between years will show you how to convert the harness if you do decide to go this route.
If there is a legitimate interest I might be willing to do a write up of the process and create some diagrams.
Feel free to PM me to 'vote'.
