Removed the plenum, lower manifold, rocker covers, and rocker arms. Broke the crank bolt loose. Maybe I'll have time to remove the t-belt stuff and the exhaust manifolds tomorrow. Just got some added responsibilities at work though so maybe not. Nasty greyish sludge was the reason for removing the rocker arms. I'm wondering how far I should go cleaning up. Lifters...cams...turbo... clean the oil pan...flush the radiator?
This is my biggest project to date. Prolly have a few questions before it's all done. BTW Satan if you read this I put the 60-2 wheel at the 11th tooth and the cam gear dots did line up so as far as I know I'm at TDC...
