bad turbo seal? help please
  • bad turbo seal? help please
    Well you could squirt some car cleaner through the throttle body and clean it up that way. Ive also heard good stuff about sea foam.
    you dont do anything, fix the leak the smoke will shortly go away. You talk like there are gallons of oil in the intake that will continue to smoke for years. fix the leak, and run at 6000 rpm and max boost for a half mile or so and you will blow most of the oil out of any little puddle spots
      ^ Sounds like a horrible idea, take out and clean the inake parts with some simple engine degreaser and wash down. Running some SeaFoam and injector cleaner wouldnt be a bad idea ether.
        84z31 is selling a freshly rebuilt turbo for cheap if you're too lazy or don't know how to rebuild your own turbo
        Funny stories!
          fix turbo. Also make sure that your oil return line isn't kinked in any way
