No cool air from vent
I'm certain that it's the hose running from the back top of the plenum, to the evap canister. Had this same problem, on 4 Z31's
Another thing you can do, if you don't want the heater for a while, is rig the water cock closed. it rests open, so you would have to pull it up, and keep it there.
lol perfect that certain part has always hada poor connection with its hose. I thought i fixed it but ill replace the entire hose now.
Thanks.
It is probably the line going to the water-cock. The water-cock is located on the firewall to the right of the battery.
First off, i have no A/C.
When driving, my car usually tends to blow very hot air even when the fan is off, slider is on cold, and the circulation is closed. More than the usual slight ventilation. It's fairly cold outside, turning the outside circulation doesn't pull in outside air, it just blows really hot air. On warm days where i want to bring in normal air, it feels like it's pulling air off the heater core.It sucks
I'm fairly sure it has to do with vacuum since the entire car is run off it.
Where should i start to look? Engine bay or under the dash? Any specific lines i could be concerned with?
Also, what does the little "floor" switch do under the driver side steering column, switching it does nothing noticable.Tags: None
