Okay to start off i took my 88 NA 5spd z out of storage on the weekend and fired it up and it was running like crap, the exhaust smelt like gasoline and idled at 2000 rpm. I ran the codes on the ecu and fixed the idle switch. Now it ran better but still idled high so i pulled off the idle up connector and adjusted the idle down from 1200 to 700 rpm. It still was running rich so i seafoamed to see if that would make a difference and when i changed the oil i noticed the old oil wasn't thick at all, it was like water and wreaked like gasoline. :shock:
So i'm wondering what could possibly cause this?
Could it be the timing is off?
Really bad compression in one or more cylinders? Head gasket?
The engine begging me to get a turbo to burn the extra fuel
