That's only if you are going to go with a Nistune system. You can probably find an 84-5 turbo ECU on here. Tbh I have heard of enough bad ECUs lately that I would probably go with one of the reman ones from rockauto and get the 1-year warranty.
85T Bad Hesitation/Hiccup/Misfire
Originally posted by FrozenZ View PostThat's only if you are going to go with a Nistune system. You can probably find an 84-5 turbo ECU on here. Tbh I have heard of enough bad ECUs lately that I would probably go with one of the reman ones from rockauto and get the 1-year warranty.
86T ECU should drive 85 injectors but I can't speak from experience.
http://www.xenonzcar.com/z31/modelse...ral+Turbo+5spd
I have an 84T 5spd ECU I could sell you but a) it hasn't driven a car in at least two years; and b) I'm in Canada so shipping's gonna be a lot more. PM me if nobody else comes through.
Originally posted by FrozenZ View Post86T ECU should drive 85 injectors but I can't speak from experience.
86T ecu should run your car, however keep in mind that the O2 for 85T and 86T cars are different types. The best thing for you would be to get a 87NA ecu with Nistune installed, but that's time and money in order to get the board, get Nistune installed, etc... Basically what would happen is Nistune would get installed into that 87 NA ecu, and yourself or the tuner would load a 84-85T factory tune. However if you wanted to get more power from your car, you'd have the option to tune your car accordingly(for things like larger injectors, larger turbo, cams, etc...).Last edited by GodofRichy; 09-20-2017, 02:44 PM.1986 z31 NA2T(Motor is being assembled)
1984 z31 Turbo 5 speed(slowly being parted out)
Originally posted by GodofRichy View Post86T ecu should run your car, however keep in mind that the O2 for 85T and 86T cars are different types. The best thing for you would be to get a 87NA ecu with Nistune installed, but that's time and money in order to get the board, get Nistune installed, etc... Basically what would happen is Nistune would get installed into that 87 NA ecu, and yourself or the tuner would load a 84-85T factory tune. However if you wanted to get more power from your car, you'd have the option to tune your car accordingly(for things like larger injectors, larger turbo, cams, etc...).
It wont be for a couple days til I receive it so I'll just have to wait until then.
So I got the 86T ECU in and by God does it feel better, granted O2 sensor is needing to be changed but I was wondering if the titania is a direct swap in on mine or anything like that. If not what can I do to run boost safely without hurting anything?
Need to change bungs & wiring, Titania are 17MM and Zirconium are 22MM.
Detailed info at http://www.xenonzcar.com/z31/ECUdifferences.html
The O2 sensor doesn't do anything that will prevent detonation, that's all in the fuel and timing maps. It's not like a modern engine management system, it's not a wideband. If you have no O2 you're going to start, cruise, and idle rich. You might find driveability issues in certain circumstances but that's all. Ir's no less safe to run boost w/o your O2 than with it.
So I drive with the O2 unplugged and tested everything out and all seemed normal. After getting to opperating temp I tried to go WOT to see how it would feel, but 1st gear stumbled on itself, 2nd, 3rd etc hesitated like it didn't know what it waned to do before accelerating as it should. I checked the plugs and they where kinda white, but it black smoked whenever I tried it in first. Any ideas what this could be?
Originally posted by JLaraZ31 View PostIAlso I've inspected the CHTS subharness closely and saw that it has some damage to it could this be my issue or would it not matter as much since the proper reading from the CHTS is going to the ECU pinouts?
Originally posted by JSM View Post
Im wondering if this could be your issue. Is it fixable? If your losing connection to your ECCS I could see it continuing to throw codes. What is the damage?
So when I was trying to swap the O2 sensors I ran into a lot of trouble as in, it would not come out with an impact, breaker bar, and it started to strip. So I'm going to resort to putting another bung for it. Does anyone have a good spot or idea to where it could be placed? I was thinking before the turbo but not sure as there's not much room for me to think of areas to put it at.
Originally posted by JLaraZ31 View PostSo when I was trying to swap the O2 sensors I ran into a lot of trouble as in, it would not come out with an impact, breaker bar, and it started to strip. So I'm going to resort to putting another bung for it. Does anyone have a good spot or idea to where it could be placed? I was thinking before the turbo but not sure as there's not much room for me to think of areas to put it at.
