OK, I took apart the front of my car again, to put on my replacement timing belt that finally came in the mail along with my CHTS sub-harness. Anyways, I was having trouble getting the belt on myself, and I remembered reading about taking the drivers side cam gear off to make it easier to put the timing belt back on. Anyways, I'm not sure if I'm glad that I did this or not (I guess I am, but it was working fine as it was), but when I took it off, a lot of broken metal pieces fell down.
Basically, that clicking that I was hearing a few weeks ago that was a result of the timing gear not being tight enough (causing excessive play in the gear and it tilting back and forth as it rotated, causing a ticking), ended up destroying the end of my cam. I'll let the pictures speak for themselves, and then continue on below.
Pictures of my Drivers Side Cam (the broken one):
Pictures of Passenger Side Cam (for comparison):
Anyways, as you can see, the end is completely shattered, and my cam gear has a TON of play. Obviously the cam has to be replaced (right?), and I definitly got the cam that has all the crap in front of the valve cover. Anyways, Haynes says absolutely nothing about taking out cams. It tells me how to inspect them, but not replace them. How hard of a job is this? I know Jason's taken out his cams before so I figured I'd give it a post here. I leave for college next Thursday, so this needs to be fixed by then. How should I go about this? According to Jason's s site any engine made before 7/87 should have the cams that match my 5/87 turbo. Right? Anyways, should I do anything else while I'm in there? I'm not gonna send my heads away for a valve grind or anything, but if there is anything cheap and easy in there that I need to replace/mess with I'd like to get it out of the way. Anyways, again, Haynes doesn't say anything about removing the cams. Perhaps the FSM does? Where should I go from here? Would it be maybe easier to replace the whole head? Are junk yard cams/heads safe? Any info/input is appreciated. Thanks!
