I replaced my Vacuum lines a couple of weeks ago with all silicone lines (thanks thumper for the write up!). Well I noticed this sound coming from the charcoal canistor when I would give the car some gas at idle or even driving. This sound would only happen between 10 and 20 mm/Hg of vacuum. No sound when idling and no sound when I am reaching boost.
The sound sounds like static from a walkie talkie. So of course I check the lines and I pinpoint which line it is. Its red line coming from the carbon canistor going around the FPR to the behind the throttle body in this picture:
I have replaced those lines and the sound is still there.
I even put hose clamps on all the ends of the lines. There are no pinches in the lines or kinks.
THe sound is also effecting my idle. It will idle around 1000rpm-1100rpm. Also my car will buck at any speed if the throttle is between 10-20mm/Hg.
So do I need a new Carbon Canistor, or is there something missing??? Please help me out guys!
