I just ran ECU codes on my 85 NA and it came up with 31 and 23. 31 is the air conditioner, which I already knew about... But 23 is the throttle valve switch. I went to EF&EC-50 in my manual and it told me how to check it... I had cont. between 18 + 25, but it was only like... .2, but its still something... and I didnt have cont. between 18-ground and 25-ground, which is also good.
I read on to find the next directions to read... Replace the E.C.C.S. control unit... WHAT!?!? Grr... Any other things I can do to see if this is bad, or is the manual usually right about this stuff?
