Congrats on your site Chris,
I turn the ignition key to start the car and all I hear is a click from the starter. I took the starter out the starter is good I put power to it and it works like it's suppose to work. It's not the starter it's good. I got a new batter so it's not the batter or the posts. All wires are making good contact and corrosion free. The contacts on the starter is good. Maybe this can help you figure it out cause I cant. When I put the battery charger on the battery and the volts on the batter with the car off is around 15-16v I crank it and it starts right up. To start my car right now I have a switch with +- connected to the starter. I leave the car in the ON position while the fuel pump is pumping and I press the switch button gives direct power to the starter and the car starts right up. If you can help me out it will be greatly appreciated.
