Injector clip retainers.
 JN210Senior Member JN210Senior Member- 2494
 Injector clip retainers.Si im not sure where all 6 of mine went…any ideas for replacement? I really dont want to run with nothing holding my clips on my injectors, I was thinkin safety wire around them nice and snug. nowhere else in town has what im looking for.1989 Nissan 300zx Turbo "MAW Edition"
 viewtopic.php?f=13&t=10617
 orrrrrrr you could buy them from nissan. they're a separate part number from the plastic clip itself.
 I'd replace all 6 of the connectors with quick release ones off a GM.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
 O rly? Do you know what that number is? I tried getting them from my dealership and they couldnt find them. and what are the quickreleases you speak of?Careless wrote: orrrrrrr you could buy them from nissan. they're a separate part number from the plastic clip itself.1989 Nissan 300zx Turbo "MAW Edition"
 edicer2Ant Eater edicer2Ant Eater- 2262
 whats the quick release ones off of?michaelp wrote: I'd replace all 6 of the connectors with quick release ones off a GM.86 NA
 87 Turbo
 Local MN car forum/club anyone welcome..... fivezeroseven.net join!
 superfast300Member superfast300Member- 41
 I just went to the junk yard yesterday and got 6 injector clips off of 2 non turbo eclipses they are the ones that just click on and you can take them off by pressing the sides in real nice if you can do it. O and they were 2nd gen eclipses they fit right on factory injectors
 id really rather not do alot of hack and solder on my harness…lol1989 Nissan 300zx Turbo "MAW Edition"
 If they use the same sumitomo/yazaki contacts, you can de-pin the contacts from your
 current connector housings with a small jewelers screwdriver and re-pin them into the
 other connector housings. No need to splice/solder anything.
 edit: I recently spliced all new injector connectors into the harness on one of my shiros.
 I found that the wires were brittle to the point of cracking when bent. Splicing in new
 wires turned out to be the best solution. Unfortunately, the old retainers got tossed.
