Rear Shocks - Reaching one upper mount nut/failing hard @
monkbonkMember- 36
I tried replacing my rear shocks today. Got as far as removing the lower 17mm bolt and corresponding bolt, jacking up the bottom shock bracket and removing two of the three upper mount nuts. Gave up on the third one out of frustration.
I've tried using a swivel, even two swivels in tandem with various sized extensions. I'm not a pro at leveraging with those swivel things, mind you.
I need some serious tippage, otherwise I'm gonna have to be content with the feel of a 70's Cadillac Brougham.Thanks,
monkbonk -
NissanEggSenior Member- 5220
Get a short 14mm socket and put it on a flexible head 3/8" ratchet. Boom, Done....
adamvann3Senior Member- 4160
I was able to get a stubby ratchet wrench in there. Just be sure to wrap something around your wrist, those speaker mounts are sharp86na - BlueZ
85t - Mr Tickles -
acemanSenior Member- 1566
if all else fails remove the speaker mount.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
sprtcrazy17Senior Member- 1685
monkbonkMember- 36
Thanks. I'll put these ideas to use. Don't have any of those tools, but I'll price check them at the auto parts tommorrow (buying brake rotors :-( )Thanks,
monkbonk -
ZFast88ZSenior Member- 1882
Take speaker mount off.The bullshit stops, when the GREEN light drops.
862sikSenior Member- 2159
I got a stuby ratchet in there, but the movment was very little, it took a while.My Build Thread -
GregmaticSenior Member- 2193
I use a stepped drill bit and drill a hole right above the last nut just larger than the diameter of a 3/8" extension. Hold the socket below the hole, push extension through into the socket, insert socket onto said nut, remove like a gentleman, repeat, profit.
Edit: reason for this is not more stripped nuts and no more bloody sliced hands.
