rb25det question
  • 87_Z31
    87_Z31
    Member
    • 73
    rb25det question
    Can a stock 87 300zx manual transmission mate to a Rb25det block, is it possible to switch over bell housing's?
  • nismopu
    nismopu
    Administrator
    • 2221
    I think all rb25's came with a r30a variant like the 87-89 300zx turbo and n/a 300zx's came with fs5w71c's as did rrb20's I believe. Sooooo, it depends which transmission you have and which one came with your rb. Fs5's swap with other fs5's and r30a's swap parts with oother r30a's.
  • Careless
    Careless
    • 13279
    z32 transmissions work with RB bell housings.
    z31 R30A bell housings work with z32 transmissions.
    therefore, rb transmissions should work with z31 R30A bell housings.
  • 87_Z31
    87_Z31
    Member
    • 73
    so this is a dumb question… r30a tranny is a non turbo vg30e tranny correct?
  • 87_Z31
    87_Z31
    Member
    • 73
    #5
    Nevermind I looked it up and I think I have a FS5W71C. Can you mate a bell housing to fit the FS5W71C from a R30A?
    BDG Game.
  • Careless
    Careless
    • 13279
    #6
    87_Z31 wrote: so this is a dumb question… r30a tranny is a non turbo vg30e tranny correct?
    FS5R30A is the designation for the TURBO 04/87+ cars.
  • nismopu
    nismopu
    Administrator
    • 2221
    #7
    87_Z31 wrote: Nevermind I looked it up and I think I have a FS5W71C. Can you mate a bell housing to fit the FS5W71C from a R30A?
    .................................................. .................................................. ........ maybe english is a second language for you?
    You cannot missmatch between the two entirely different tranny's. I explained that above.
  • Careless
    Careless
    • 13279
    #8
    [quote]nismopu wrote:
    you didn't say they cannot be switched, you just said 71c's go with 71c's and 30a's go with 30a's.
    no indication of what's not possible :-P.
    he can read fine.
  • Racinjitter
    Racinjitter
    Z Force Commander
    • 3128
    #9
    For a 71c, you need a rb20det/rb20de or a rb25de trans. For a 30a, you need a rb25det trans.
    No the RB bellhousing will not bolt up to a VG30E/T and no a VG30E/T bellhousing will not bolt up to a RB.
