z31 tune up
luismaster7Junior Member- 2
z31 tune up
Im looking into getting a z31 for about a grand. the guy selling it said it needs a tune up and a new fuel filter.
Now i know basics but im not to much in depth on some stuff. I know what a fuel filter is but what does a tune up actually consist of.
I
ve already googled it and many of the sites seem to me like you need a foundation on mechanics. also is a tune up expensive because
i dont want to spend another 2-3 grand just to make this thing run smoothly.
thanks -
reddzxSenior Citizen- 6440
Tuneup -
an old-fashioned maintenance term that's nearly non-existent today. With electronic ignition and fuel injection came computers that took over control of engine settings. Early versions allowed for some tinkering, but today's engines require advanced equipment and training.
You can, however, replace normal maintenance parts and still see improved engine performance. Here are common maintenance parts you can replace to significantly increase performance and reduce major problems:
Basic Ignition Parts
Spark Plugs: Spark plugs are good indicators of engine condition. Removing and inspecting spark plugs tell you a lot about how well the engine is running and what may be causing problems.
All spark plugs should be removed and checked every 30,000 miles - even if your car is "low maintenance" - you're told to change spark plugs at 100,000 miles. This prevents the plugs from seizing in the block, causing expensive repairs down the road.
Always note which plug came from which cylinder. This tells you if a particular cylinder has a problem. BEWARE: New spark plugs can make a difference in your car's performance but only if replaced with the appropriate OE replacement plug.
Distributor Cap & Rotor: Both the distributor cap and the rotor are usually plastic and, thus, deteriorate with age and use. Cracks may develop, allowing moisture in. The metal contacts on both can then corrode, causing misfiring. These parts should be replaced at recommended intervals or if showing any excessive wear.
Spark Plug Wire Sets: Spark plug wires have become less of a problem than before. New materials and sizing have reduced failures. Electronic ignitions have increased operating ranges.
Now these should be tested for proper resistance before replacement. They are no longer replaced routinely with the cap, rotor and plugs.
Filters
According to experts, changing filters on a regular basis may have more to do with your car's longevity than any other single factor.
Oil Filter: Oil filters are easy to replace and help prevent unnecessary engine wear. The job of the oil filter is to remove soot, rust particles and other solid contaminants from the oil. Oil filters should be replaced with engine oil every 3,000 miles.
Air Filter: Air filters remove dirt by trapping particles as air passes through the filter media. They also protect the carburetor in older cars, preventing dirt from clogging the air bleeds and metering jets. They protect fuel injectors in later-model autos.
Air filters should be replaced every 20,000 miles but more often if you live or drive in dusty areas. Any filter that looks heavily loaded should be replaced regardless of the number of miles, as should any filter which shows any type of damage.
PCV Breather Filter: The PCV breather filter assures only clean, filtered air is drawn in through the PCV breather. A clogged breather filter prevents the PCV from siphoning away the blowby gases and moisture created by engine combustion, resulting in oil breakdown and sludge buildup. The PCV breather filter should be replaced every 30,000 miles; however, yearly replacements are a good preventive measure.
Fuel Filter: Contaminants can get into your fuel system and if not trapped by the fuel filter, they can clog the injector inlet screens. If dirt reaches the injector itself, it can clog or damage the pintle valve and seat. In older cars, dirt can plug the carburetor's fuel metering orifices.
If the fuel filter is not replaced regularly, fuel flow to the engine will become restricted, resulting in stalling, loss of high speed power and hard starting. The fuel filter should be replaced every 30,000 miles; however, professionals recommend a yearly fuel filter change and a change whenever other fuel system parts are replaced.
Automatic Transmission Filter: Properly filtered transmission fluid transmits energy, plus it cools and lubricates the moving parts of the transmission.
A clogged transmission filter can produce transmission slippage, engagement problems and hesitation. Experts recommend this filter be changed every 12,000-15,000 miles to extend the life of your automatic transmission.
1991 Hard-body 2WD
PulseCodeSenior Member- 1522
Very nice response! Clear, concise- This post should be stickied.
Imagine how many people are looking for this kind of info up front.Everything is Meaningless. -
flatfootSenior Member- 253
I agree with the list above.
I just want to add a new timing belt since you don't REALLY know when the PO did the last one.Life's short
Go fast
Have a blast
Leave a good looking corpse
