cams springs and valves
MuhKaydenZSenior Member- 657
I need to replace the cams in the vg33 with ones fron the vg30 now the guy I bought my vg30 from said he replaced the cams (mild regrind), schneider springs, and vales (3 grind valves) as well as redoing the valve seats can I use those or should I just get some oem ones? not too farmiliar with regrinds thanks!Click here to view my Stanced VG33ET Build thread / Click here to view my Feed Back thread
shromySenior Member- 2189
You can use them, but you will need to have the valve seats in the 33 head cut for the 3 angle job.Hmmm, Whats next?
84ZXT -
88sinZSenior Member- 2019
shromy wrote: You can use them, but you will need to have the valve seats in the 33 head cut for the 3 angle job.
info on the differences? AllData listed them as the same, that's why i ask -
When you do a 3 angle valve cut the seat also needs to be cut for the 3 angle job. since his 33 heads are stock they have the stock angles cut into them.Hmmm, Whats next?
84ZXT -
