how long does it take to get regrinds
akurtzer57Senior Member- 205
Schneider cams are garbage. Go with isky cams. I believe turn around is about a week or two.
1988 570zx SS Edition
You can call.
amrebootBanned- 9875
That is solely your opinion.bleakdragonmage wrote: Schneider cams are garbage. Go with isky cams. I believe turn around is about a week or two.
I and a good amount of other members here run the Schneider re-grind cams.
If broken in properly per their instructions, you will have no problems.
I run the 274-70h cams and difference is night and day compared to stock. -
[quote]amreboot wrote:Not just my opinion and yes they may work and run without problems, but they could be out of spec. If i remember correctly SATAN had ordered their cams and measured them UPON ARRIVAL and had found them to be not the correct specs. And by that i mean not the wrong cams, but off by degrees. And this was on more than 1 set IIRC. And i believe isky is cheaper. Well, i know it is for me because they're local and i can pick them up.Originally posted by bleakdragonmageSchneider cams are garbage. Go with isky cams. I believe turn around is about a week or two.
[quote]bleakdragonmage wrote: [quote=amreboot]Do you also know that Satan sold his ISKY's and went back to Schneider before he parted with the vg30?Originally posted by bleakdragonmageSchneider cams are garbage. Go with isky cams. I believe turn around is about a week or two.
If you google you will see that all re-grinds (all manufactures) have a potential of being out of spec. That's why its highly recommended that you measure.
I called Schnedier and even they said to do so before installing.
I measured mine, all in spec. -
Actually i didn't know that he went back to schneider. But then again i've never followed his build as closely as most… But i searched through some of his posts and i never found anything that said he switched back to Schneider either… But then again, i also dont really talk to SATAN so yea…amreboot wrote:
