alternator frying electronics?
 MuhKaydenZSenior Member MuhKaydenZSenior Member- 657
 alternator frying electronics?So I bought a quest alternator forever ago and just recently installed it now when the car was running I noticed my injectors were clicking loudly which I had never heard before and my wiper motor smoked a bit and now doesn't work properly do I have the wrong alt or is the output too high?Click here to view my Stanced VG33ET Build thread / Click here to view my Feed Back thread
 no, the voltage regulator on the alternator is most likely pooched.
 on my old alternator i saw 18 volts and pretty sure i fried a lot of things. car hasnt run the same since, but i'll be replacing both harnesses in the new year.
 da** it so if it fried the injectors can I replace just the injectors and alternator or do I need to replace the wiring as well? thanks!Click here to view my Stanced VG33ET Build thread / Click here to view my Feed Back thread
