2 lift possible?
Re: 2" lift possible?
By the way Mid, did you get those shocks?
I would be interested in seeing this being done. Hit 'em with teh SWAG.
[attachment=0:1y6383bk]300zxPOR69.jpg[/attachment:1y6383bk]
2001 Mazda Miata LS
also a 1989 Nissan 240SX
KingmanSenior Member- 1294
Wheeler's trick, big ass zip ties to secure the coils to the seats.midian wrote:
Or you can make custom spacers for rear strut mounts (actually you'll also need same for front).
Big travel of rears won't be good, simply because spring may become uncompressed fully and fell away. -
midianSenior Member- 421
[quote]xbxrxtorquex wrote: By the way Mid, did you get those shocks?
[attachment=0:3hxjpe09]300zxPOR69.jpg[/attachment:3hxjpe09]No, I didn't. Z is not offroad car, for such cases Nissan designed D21 series and Patrol.
150mm of stock clearance enough for me even in cases then I drive country roads (very-very occasionally and very smooth). I had problems only until I changed 'kg/mm' lowering progressive springs (sold already) to stock.
But I mentioned Tein, cause I was at official dealer's workshop and asked such question.
They say - any height, any stiffness, but it will costs you $450 per one.
Also, I mentioned spacer for struts, you saw maybe, use if you unplug swaybar and lift car, removing rear springs could be done w/out removing bolt, fixing strut to arm (not easy like with removed bolt, but it could be).
Kingman wrote:^^ agree.Wheeler's trick, big ass zip ties to secure the coils to the seats.Originally posted by midianOr you can make custom spacers for rear strut mounts (actually you'll also need same for front).
