Timing Belt Change
FilipeSenior Member- 524
Thanks for the clarification. I had originally chosen Executive Nissan, but will be going with Rock Auto supplied ones now. Thanks.Careless;327276 wrote: That's not what I said. OEM seals are not made by Nissan. If you buy them from nissan, you'll see that they are simply repackaged NTN, NTK, NOK, or SKF seals. The cam and crank seals are not proprietary sizes, so any third-party parts company has access to the same seals that Nissan repackages. In other words, they are a standard size- not a Nissan specific size. but use what you want. don't let me stop you from spending an extra 4 or 5 bucks to get them from Nissan.
reddit.com. -
wbnethery3Senior Member- 437
Bumping this thread… did you complete this job? If so, how did it go?'86 NA - original owner (1986-93) and final owner (2005-present)
Wow! Thanks for reviving this! yes, I did complete the job, it went very well. I also created a "how to":
The Z31 link is broken, so refer to my local z club page:
http://forums.ctzcc.com/viewtopic.ph…53b3f32292b4ce
