timing belt movement
xanmanz31Senior Member- 218
just finished timing belt and NA2T noticed my timing belt has moved back almost against the rear timing cover. cams and crank are tight tensioner isnt too tight. i also flipped it around so the arrows pointed out .
any ideas? -
Reading and attenion to detail will always be your friend. Get a manual and read it. Timing belt is rudimentary.Cha iro
just washers on outside sprocket straight to camG-E;n762065 wrote: Do you have those tapered washers on both sides of the crank sprocket?
i think it ended up being loose sprocket bolt as retarded as i look ill admit it. i was just getting in a hurry i wanna drive it so bad.
after i tightened it i was able to start it fairly easily and then the dreaded oil seepage from exhaust manifold. im doing intake valve seals now.
