HELP removing distributer rotor
samshadowSenior Member- 176
So my Z is saying bad crank angle sensor. Took off cap and tried to remove rotor but it wont budge. Has anyone got any tips on removing the rotor? Besides removing screw?
mizagyuSenior Member- 539
buy a new rotor, take vices grips and rip the old one off. if its stuck on, then it probably is old enough to need replacement. -
HardwayMember- 86
I am not sure about all 300zx's but all my '87 and '88's have a small bolt holding the rotor on. Look under the rotor hat on the shaft there may be bolt. If not, vise grips and destroying it may be your only option.1988 300zx Turbo GL - 5spd, t-tops, all stock and staying that way. -
KingmanSenior Member- 1294
Axel kainModerator- 1221
You do also know the CAS is below the rotor and the cover plate? why not just replace the dist. or are you going to put in a later model (maxima) CAS pickup?Damn dirty angels....these cars!
sigpic -
was going to just replace CAS since my Z is throwing the code. Yeah got it off with heat gun and vice grips.
