Distributor Rotor Timing. Correct Orientation?
NuCOTechMember- 76
Just looking to confirm this is correct or if it is a tooth off. The white out from the previous owner(s) has me second guessing myself. It looks correct going by the picture from the FSM, but I'd rather have a second opinion.
KingmanSenior Member- 1294
Clearly that is square tooth timing compnents. I threw those out with the old belt and went round tooth.G-E;n764402 wrote: That looks an awful lot like a vg33 rotor…Cha iro
NuCOTechMember- 76
I have no idea. That is what Autozone gave me. It looked just like the old one I took off.Kingman;n764387 wrote: Looks good.
Excellent. Thanks
G-E;n764402 wrote: That looks an awful lot like a vg33 rotor… -
NuCOTechMember- 76
Are there any benefits going to the vg33 components?G-E;n764402 wrote: That looks an awful lot like a vg33 rotor… -
The z31 era oem rotor is wider at the contact area, allowing a much larger range of timing, which is why people are able to get the car to fire when it's off a tooth… I have no idea if there's any actual benefit though, just saying
