swapping z31 t-5 to 30a
Cesar HMember- 42
Hey guys, Just wanted to know for those of you swapping your T-5 transmission found in early Zs to the 30a found in the older turbo models 87-89 do you guys also change your electronic speed sensor. Of course this is for those with the digital dash cluster. -
So 87-89 is older than 84-86 now? :P They'd be newer. But that aside, you don't need to change any speed sensor. Just screw the speedometer cable/sensor into the drive and be done with it.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Son of LarsSenior Member- 550
I asked a similar question about swapping speedo cables between auto and manual, but it appears it was in the wrong forum?, so it was deleted before I read the replies. -
Cesar HMember- 42
Ok so then I did not need to buy anything I could use all my 90a comoponents? I have both 30a and 90a pinion gear assemblys
