Na2t iacv
1986zMember- 40
1986zMember- 40
Switch to the turbo iacv? I know you can rewire it to work. I'm just wondering if there are any differences other than the wiring. -
xanmanz31Senior Member- 218
matt85turboSenior Member- 101
Just ditch it. Flip the idle set screw upside-down and set the idle with that. Or tighten the throttle cable to where you want the idle.
