Water Lines to a Medium Size Turbo on an 85T
jamesSenior Member- 978
Hi All
I would like your suggestions as to where to Run AN6 equivalent size water lines. I have Ordered Pushlok line & fittings to match my Rocker covers. And I don't really give a shit if i have to weld / drill tap or generally engineer something to make it work
That is what I got to start with, and being an 85T it had no OEM water line connections.
Post your Suggestion GO !85 Turbo Slick Top
I ran mine through the lim nipple & thermostat housing nipple that comes from under the back side of the lim.Attached Files- turbocoolantlines.jpg (17.4 KB)
My build thread (: -
NissanEggSenior Member- 5220
To the water pipes at the rear of the engine/under the LIM.
